Back Forum New
Mini Breadboard Power Supply
Another breadboard power supply designed by wrobot. it can directly takes power from DC wall wart and outputs a selectable 5V or 3.3V regulated voltage.
Compare to other breadboard power supply designs, this one provided  mini-USB port like the Arduino family, you can toggle the switch and select your power source. (USB or dc jack). We also used JST-2pin power jack ,the one as on Arduino family,
With this board, you can send power to both power lane of the breadboard, and each side has a on/off switch.
This breadboard power supply support mini breadboard :
This breadboard power supply also support standard breadboard :
Click to download the schematic diagram
Back Forum
